Replace Window Channel Felt?
Madison, MS
It seems like my window felt in my 09 LC is disintegrating. Any ideas for a replacement?
Actually I just ordered a set off Ebay for under $50 that look VERY promising. I may install them over this weekend and will provide photos and comment. Decided to take a gamble vs the couple hundred bucks the Toyota version were asking
I replaced all the outer window mouldings. Is that what you're talking about?
Ah, yep, I've never seen an interior sweep do that without having something foreign on the window
Mine have that from an old tint job that started to go bad, and I think it was the adhesive from the tint. I cleaned the window and the felt with glass cleaner, rolled up and down, and repeated. It got better, but still occasionally I have to clean the smudge off the glass in that spot. I've considered lightly trimming back the felt in that area with a sharp razor blade which would probably take care of it.
The outside is easily replaced (I swapped mine all out this summer). I think the inside is attached to the door card.
Can you clean the interior felt?
Ooooooo! I had tint removed from this weirdos, and it’s been doing this ever since. I keep cleaning up the smudges, so I figured it was something else. Maybe it’s just old glue that’s deep with the bowels of the door.
Based on the pic you posted, I think it's glue right there on the felt. I'd clean that up. I was hesitant to go with a more aggressive solvent like goof off, but maybe that would work.
