MScruiser
obsessive-compulsive oppositional-defiant wise-ass
The electronic seat tilt knobs were both missing and broken when I bought my 1997 80 Series last year. As the plastic post that is integrated into the seat controls were broken off at the base, the only way to get control working again, would have been to buy an entire control module for each seat. At over $150 a pop, that wasn’t going to happen. Another option is to jam a wood screw into the broken tab. While this does regain control of the switch function, it looks like crap. And since I am trying to restore this peach of a Collector’s Edition, it wasn’t going to fly.
The first thing I had to do was track down 2 oak colored knobs in good condition. This was a lot harder than it sounded, and took me several weeks.
Once in hand, I came up with a decent solution, that was relatively easy to do as well.
Firstly, this will ONLY work if the original black plastic pivot post is still present on your control module. See below:
Next, look in your screw/bolt bin and find one with a head that is the correct diameter to fit snugly within the small recess of the knob. You need to ensure it’s around 1”long, but if you’ve got a grinder, you can fine-tune the length later. Just make sure it’s not too short before proceeding to the next step.
Next get some strong epoxy (I’m using JB Weld) and fill the void/recess in the back side of the knob.
Then install the screw into the recess and pack the excess epoxy around the screw head.
