Removing the rear door inner panel
Discussion in '100-Series Cruisers' started by derekb41, Aug 7, 2005.
  1. derekb41
    derekb41
    90
    Media:
    3
    Albums:
    1
    14
    Jun 15, 2005
    St. Louis, MO
    Is the procedure the same as removing the front inner panel?
  2. PabloCruise
    PabloCruise SILVER Star
    17,417
    2,116
    Jun 3, 2004
    Northern Colorado
    Ha ha, sometimes Search doesn't lead to a pot of gold...
  3. FxFormat
    FxFormat
    1,025
    1,430
    Dec 5, 2016
    DC
    Yup they’re exactly the same, undo all the bolt around the edges, 3 pushing type tabs, a screw behind the door lever, and there’s a hidden bolt under the window switch. Remove the window switch by prying the front and pulling up to reveal the screw. After that, pull the door panel towards you and lift up.
    PabloCruise likes this.
