Removing the 2F and putting in the 12HT (1 Viewer)
Ducks
Oregon
Hey All,
I'm removing my 2F and installing a 12H-T. The main thread is in the diesel section.
Right now I am pulling the 2F along with the h42 and split case all connected together.
How do I remove the stick shifts for the transmission and split case so I can pull the engine out?
Cruiserdrew
On the way there
Sacramento, CA
Hey All,
For the 4 speed shifter-Remove the boot-at least the bottom of it, find the collar at the base, push it down and turn counter clockwise. It pops out with some spring tension.
The transfer shifter-remove the boot, disconnect fron the high low shifter, unscrew the shaft from the side of the tranny. You may also need to disassemble the shifter off the shaft.
NLXTACY
Wits' End
Supporting Vendor
West Hills, CA
I watched as Mark used two large screw drivers and pushed down hard on the ring and twisted it to get past the pins that are under there. There is a spring that is pushing on a cap that is keeping the shifter in place.
Ducks
Oregon
Thanks guys. Came out very easily. Surprising what a little bit of knowledge will do for you.
