Been monitoring a small oil leak for a while from the rear. My guess is the o'ring right above the rear main seal, but regardless, the rear cover will need to come off.
Engine has 345k miles, and I am debating on if I should do this job as an engine out, to reseal the rear cover by the book (by removing the oil pan), or just pull the transmission and throw a bit of FIPG at the corners and pray.
If I end up doing an engine out on it, is there anything else I should do "while I am in there"? I have recently done quite a bit of work baselining the truck. Just about every rubber hose has been replaced, heater tees, valve cover gaskets, timing belt & water pump, steering rack & power steering hoses.
I think there is also another identical o'ring in the front cover that I will also look to replace.
Anything else anyone can think of? Or thoughts on doing the job with just pulling the transmission vs engine out?
Thanks.
Thanks.
