Is it possible or even a good idea to try and remove the transfercase output shaft while the tranny/transfercase (1976 4 spd w/ Orion transfercase) are still attached to the engine. Rear bearing on the output shaft is shot and needs to be replaced and I am trying to figure out the best way of replacing it without removing the transfercase from the tranny if possible. Any help is appreciated as always. Thanks.
. The rear is not as bad but this is the first time that I saw one like this. Needless to say that I am checking/replacing all the bearings and washers. Good stuff. Thanks for the help.
