It's somewhat heavy and awkward so either have a buddy hold one side for you or build up a small platform to rest one side on as you remove the bolts and gravity does it's magic...
Step one: turn bolts to the left.
Step two: done.
Step two: done. Step two:listen to snapping bolts as you turn Step three: rejoice especially if you wont use those bolt holes again.
Torch is the best... Need the captive nuts for aftermarket bumpers
I had to use an angle grinder
I needed a sawzall..... Even though my undercarriage is far from a rust bucket.
My 2135 ti max, I won't say struggled, but it definitely took some time to pull em. Lube em up, smack the face of the bolts hard with a hammer and giver her hell.
http://www.amazon.com/dp/B000WMN2GU/?tag=ihco-20ya'll need to hit the gym!!
Same way I did it last week.If your talking about an under the frame style hitch, my bolts were full of sand/crap, so pretty tight. Had to crack the loose with a breaker bar. Then I just layed under the rig and supported the hitch with my knees and dropped the bolts out. John
