Remove & replace 1994 air filter assembly from fender well?
Chicago, IL
Hi...been searching and find a lot of new system installs (K&N etc) and filter replacements but can
someone recall a thread of how to pull the stock system out? I got a rust hole under the assembly I gotta patch...
Chandler, AZ
Hi...been searching and find a lot of new system installs (K&N etc) and filter replacements...
Depending on your priories, in most cases, the stock system is better than the alternatives. It is very well designed and executed.
but can
It's easy, some clamps to loosen, unplug the harness (don't take the screws out!) and IIRC 3 bolts.
Chicago, IL
thanx guys...the reason i asked was a few other threads had warned of breaking something...but sounds simple enough...will reach out for a fender well if i cant patch this one adequately...thanks again
arcteryx
Supporting Vendor
Austin
I have a few as well, but due to the size they are not cheap to ship :( If you can find one local that would be best, unless you are getting a lot of things from a source, then it balances out.
