remove exhaust and intake manifold
Discussion in '40- & 55-Series Tech' started by chaka, Feb 21, 2007.
  1. chaka
    chaka
    195
    Apr 16, 2003
    Washington DC
    Hello all,
    I am finally finding time to push forward with replacing my exhaust. I am removing the manifolds to have them milled, as well as to gain access to a sheared off exhaust pipe stud.
    That being said, I have removed the carb, EGR and Gulp valve. I have also removed the 4 nuts that hold the manifolds on to the block. In the picture I have circled two of them.
    Should this thing pull right off? I don't know how long it has been since it was last off the block, but I am having trouble getting it off and have only used a rubber mallet to whack it a few times to try and free it up. No luck.
    any suggestions? I am so close to getting this thing off and being able to drive this rig!
  2. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    How many nuts/fasteners have you removed? I count 8 if you include the bolts on the ends.
    Ed
  3. chaka
    chaka
    195
    Apr 16, 2003
    Washington DC
    so is it safe to assume there are 4 above and 2 at the end and 2 below? I think my ends aren't there...so that may leave 2 more below... any tricks to getting to these?
  4. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    Socket and extension. I run a header, but in my case I put the socket on the nut then attach the extension and ratchet. The socket will not fit between the intake and the header.......IIRC. The ends are used with a header and certain manifolds, but many exhaust manifolds do not have a provision for fasteners at the ends, maybe just later ones?
    Ed
  5. Nomis
    Nomis
    1,191
    17
    Feb 12, 2004
    Tampa
    Showoff. . . .
    That thing running yet? :flipoff2:
  6. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    Yup. Old, often-posted pic. But it does show the studs nicely:D
    Ed
  7. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    24
    Jan 3, 2003
    McCall, ID
    Ed's a studly kinda guy.
    Likes to show his studs.
  8. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    I offer to show my studs all the time, but the number of takers is dwindling:frown:
    ed
  9. chaka
    chaka
    195
    Apr 16, 2003
    Washington DC
    Ok. So thanks to the studly diagram I have removed the 2 remaining nuts underneath the intake manifold. Now I was trying to get the manifold assembly off, but I have one final pipe running from the cooler to the intake. Anyone know what size the connection is? seems to be bigger then anything i've got other than channel locks, and I don't want to strip it.
    it is #2, #27 on this page, and mine is assembled the way the inset is next to the pipe diagram (2 ends both screw in instead of connecting via a flange of sorts.
    http://www.sor.com/sor/cat047.tam?xax=16423&page.ctx=cat047.tam
    so can anyone advise?
  10. Fast Eddy
    Fast Eddy
    14,303
    2,016
    Apr 5, 2006
    Morgan Hill, CA
    Pull off the whole EGR assembly by disconnecting 10, 12 and the whole #7.
    [​IMG]
  11. chaka
    chaka
    195
    Apr 16, 2003
    Washington DC
    Fast Eddy,
    My assembly doesn't have a #12. it has another 27 on the veritcal connection... i was curious if anyone knew the size of it... or if the manifolds could comea part with it still attached?
  12. kulangot
    kulangot
    1,735
    116
    Apr 15, 2003
    Los Angeles California
    Try an impact "wobble" socket.
    1/2 inch snap on version will run you about 45 bucks and is a pleasure to use even if you don't have an impact gun (yet). Matco is cheaper but Snap-On is better (I have both).
    -Stumbaugh
  13. Pin_Head
    Pin_Head
    14,461
    2,036
    Feb 6, 2002
    OC, CA
    Just remove the bolts holding the EGR cooler to the block and remove the entire manifold assembly as a unit. If you need to fool with the EGR plumbing, you can do it with the manifold out so that you have room to work on it.
  14. snailwagon
    snailwagon
    1,042
    3
    Jun 11, 2004
    high desert, ca
    1974 had a different attachment to the exhaust manifold than depicted in the SOR diagram. I think it is a 23mm nut or something. At the least, use a large crescent wrench.
    Take a ruler and measure it, most cruiser bolts/nuts in that range varied by 2mm increments.
    Do you really need an EGR?
  15. Waorani
    Waorani
    409
    8
    Jun 7, 2006
    Auburn, AL
    I'm getting ready to stick my intake manifold and new MAF headers on. Exclusive of the two end bolts I think originally there were only 2 studs and the remaining 4 were bolts. I like studs better - any reason not to use studs on all 6 ?
  16. mr_manny
    mr_manny
    1,655
    12
    Apr 10, 2004
    san pancho, ca
    I'm using studs, they are still available from toyota for a few bucks a peace...
    [​IMG]
