So the fires here in Colorado have me worried. I live in the trees and I've done alot to prepare my property - cleared trees back, removed brush & low branches, keep the gutters clean, stucco siding & paver patio. But I watched some houses go up last night that looked like they were at least as prepared and not in areas as heavily wooded as mine. I think alot of it is embers landing on roofs. I want to go with a steel roof eventually, but it's not in the cards at the moment.
So I'm thinking about running some pipe up through the roof in two places and putting some big sprinkler heads on. I have no delusions that it will mean anything in the event the structure catches fire, but figure it may help alot with embers on the roof and immediate area.
I'm also concerned that I'm often away from the house, and in the event of an evacuation I may not be able to get back to turn it on. Neighbor has the key, and I could show them how to use it ... but they're often away also and if things get tight I expect them to take care of their own stuff first. So I'm thinking about putting two valves in parallel - one manual, so I can still open it if power is lost, and one solenoid hooked up to the internet in some manner so that I could activate it remotely. Possibly via an existing home automation system - though that's kind of overkill. I'd prefer to just roll my own scripting so I could send it an email or txt message to turn it on or off. Just have to learn how to control an external device like this.
I can set this up in a water heater closet with a 3/4" supply on the 2 story part of the house. Would likely have to do it in the crawlspace with 1/2" supply for the other, 1 story end. I'm on a water district which has its own backup generator so supply should be independent of power, for awhile at least. Typically have in excess of 70 PSI to work with, though that would likely change in a fire situation.
Couple of decent looking brass sprinkler heads on Grainger:
Sprinkler Head, 1 In, NPT, Brass - Sprinkler Valves and Hose Swivels - Lawn and Garden - 4NDP6 : Grainger Industrial Supply
Sprinkler Head, 3/4 In, NPT, Brass - Sprinkler Valves and Hose Swivels - Lawn and Garden - 4NDP7 : Grainger Industrial Supply
I know some of you guys have alot more experience with this stuff -both on the plumbing side and the fire side. It should work plumbing wise. Need to figure out the control side. But could this be effective, or is it just pissing on a forest fire - so to speak?
