Refilling Transfer Case
Discussion in '80-Series Tech' started by 92Cruiser, Mar 2, 2004.
  1. 92Cruiser
    92Cruiser
    121
    Mar 28, 2003
    Anybody know an easier way to refill the transfer case? I can only get about half of the gear oil out of the botlle and have to grab another bottle because of clearance. Somebody has to know of a quick way of doing this.
    Thank you,
    Brian
  2. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    look on page 2 for a post by dvader on this subject.
    Dave
  3. DoggieStyle
    DoggieStyle
    13
    Mar 2, 2004
    Sears makes a hand pump that I've used for years to do diffs and xfer case. Threads right onto the bottle and has 2 lengths of tubing. Works wonders.
  4. Wayne
    Wayne Bought by His blood, kept by His power
    974
    251
    Oct 12, 2003
    Middleburg, Florida
    Autozone also sells a manual syphoning pump (less than $10) that allows you to suck almost 3/4 of a qt. of fresh oil up into it, and then inject it into the trans case, diff, etc., using the hose provided ....... worked great for me.
    Wayne S :cheers:
  5. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,057
    528
    Dec 13, 2002
    Knee deep in hookers and gin
    When I recently did my transfer and refilled with M1 I used a chunk of fuel line stuck on the nipple of the bottle. That allows you to put the bottle up high. Then I stabbed the bottle near the end to let air in.
    If not using Mobil one I use a 5 gallon bucket with a pump.
  6. IdahoDoug
    IdahoDoug
    8,848
    248
    Aug 9, 2003
    If you are without other resources, you can pull the top off one bottle and keep filling it with the half empties, also.
    DougM
  7. alia176
    alia176
    10,365
    Albums:
    1
    783
    Aug 21, 2003
    Tijeras, NM
    I use one of those 5 gal pails of gear oil and a mondo hand pump. The pump is attached to the lid and pumps crap load of oil. When you have four all wheel drive vehicles, you go through gear oil quickly! I picked everything up at Pep Boys auto. The best part about this method is that there's very little mess.
  8. Safado
    Safado
    1,157
    1
    May 21, 2003
    Here....mostly.
    [quote author=IdahoDoug link=board=2;threadid=12423;start=msg114207#msg114207 date=1078290484]
    DougM
    [/quote]
    That's exactly what I did last night.
  9. DRTDuck
    DRTDuck
    624
    10
    Mar 28, 2003
    Boulder, CO
    A funnel with flexible tube, 3 or 4 bucks at the local auto parts store.
  10. cornerman
    cornerman
    59
    1
    Jan 30, 2003
    Seattle, WA, USA
    I can't find that "dvader" link. I saw it a few weeks ago, but now I can't find it. Anyone?
  11. RavenTai
    RavenTai
    6,048
    38
    Nov 16, 2003
    Dixie co. Florida
    [quote author=cornerman link=board=2;threadid=12423;start=msg125327#msg125327 date=1079998149]
    [/quote]
    https://forum.ih8mud.com/index.php?board=2;action=display;threadid=11288;start=0
    there are a lot of good ways to fill described in that thread, I used a small drill operated pump and a few fittings all from the heardware store
  12. Augie
    Augie
    526
    3
    Nov 16, 2003
    Plastic bag or big ziploc also could be used. Fill it with oil, tie the end and then cut a small hole at one corner.
  13. otis22
    otis22
    30
    Oct 22, 2003
    Raventai's solution is very slick. I tried the other methods suggested and most were a pain. Just make sure you get the clear hose with the fillaments in it to stop it from collapsing.
  14. e9999
    e9999 You want to do what...? Moderator
    16,593
    487
    Sep 21, 2003
    US
    just saw a terrific gizmo. Looks like a huge syringe. Made by Pews (?) I think, the company that does all the grease guns. For oil and grease. Will squirt something like a pint at a time, even upwards. Can also be used to suck out stuff or squirt cleaner on etc. Sure looked like a good way to go to me...
    E
