SOLD REDUCED Evergreen, CO 1994 Triple Locked (ARB), 5.29 gears, Icon suspension see parts list 1994 FZJ80 (1 Viewer)
Year
1994
  1. 80 Series
Evergreen, Colorado 80439 United States
Mileage
175000
Color
Green
Asking $14k OBO, No trades - SCROLL down, I've added additional pictures in the replies
Here are the specs and everything currently installed, as well as parts included in the sale:
1994 FZJ-80 Triple Locked (ARB)
174,950 miles
There is a little rust on the rocker panels, clear coat peeling, and has some body repairs (primer’d).
Icon Stage 3 Suspension System (Adjustable remote reservoir shocks with Front Hydraulic Bump Stop)
New factory rear bump stops on Wits End Blocks @NLXTACY
King Suspension steering stabilizer
Front sway bar disconnect
@Delta VS
Delta Vehicle Systems 4” radius arms
Delta Vehicle Systems 3” Panhard relocater
Delta Vehicle Systems front Hydraulic Bumpstop Mounts w/ 1" Spacer
2 New Double Cardan Driveshafts
New Asin Fan Clutch
New Asin Water Pump
New CSF metal radiator
New belts
Nitro 5.29 gears
RCV Performance Front Axles
Nitro Silver Chromoly Full-Floating Rear Axles
ARB lockers front and rear
ARB air compressor, interior switch for front and rear lockers
Center diff lock (4hi & 4low)
Front and rear axle breathers routed to engine compartment
ARB bull bumper
Wet Okele Seat Covers
New brake calipers front and rear
New master cylinder
New exhaust from downpipe to tail pipe, including new catalytic converter
NOCO Genius onboard charging with external plug
New Optima Red Top Battery
New Optima Blue Top Battery (not installed)
4x 35” Goodyear kevlar MTRs (mounted)
5x Method Race Wheels MR105 Beadlock, 17x9, -38mm Offset, 6x5.5, 108mm
Slee transfer case skid plate
Metal Tech Sliders
4x4 Labs 3rd row seat baskets
Speski Off-Road Cargo barrier
Kut Snake Fender Flares (front right fender is cracked)
No AC compressor
no speakers installed
No Radio installed
Spares:
5x 32” factory size tires mounted on stock rims (spares, not mounted)
Brake booster
Repacement “Toyota” lettered steel grill
Hi-lift jack
Fire extinguisher
Apologies if there are duplicate photos, trying to get all these up in between meetings at work.
174,950 miles
@Delta VS
New Asin Fan Clutch
New Asin Water Pump
New belts
Nitro 5.29 gears
ARB bull bumper
New master cylinder
Metal Tech Sliders
No AC compressor
No Radio installed
Spares:
Brake booster
Hi-lift jack
Fire extinguisher
View attachment 2745677View attachment 2745678View attachment 2745679View attachment 2745680
