Redline Gear Oil
Discussion in '80-Series Tech' started by Romer, Jul 2, 2005.
  1. Romer
    Romer fatherofdaughterofromer Moderator
    11,058
    2,677
    Sep 14, 2003
    Centennial, Colorado
    Based on Carys recommendation and the Bobistheoilguy website, I put Redline 75-90Wt (not the ns stuff) into the tcase (center diff). I bought it in gallon jugs and use a pump to put it in. A lot easier than the squirt bottles (with a lift) and according to the oil website, much better than any other synthetic for the application.
    It was $35 a gallon, less than Mobil 1
    I bought enough to use in Rachels 4runner when we get it back late tomorrow or Monday.
  2. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    I have heard good things about red line gear oil, where are you getting it for less than M1? I have found it to be more expensive through mail order.
  3. dd113
    dd113
    2,922
    7
    Jun 13, 2003
    I love the stuff. We use 90w-140 in differentials and the 75w-90 in TC and trannys. I have not found it in gallons but can get quarts locally for $7.25 ea.
  4. Romer
    11,058
    2,677
    Sep 14, 2003
    go to the redline site and look for dealers in your area. Make sure the list Gear oils under products.
    David - I was going to use the 75-90W in my daughters 4 runner diffs. Is that a bad idea, you use a heaver weight?
  5. dd113
    dd113
    2,922
    7
    Jun 13, 2003
    The 75w-90 will be perfect. I think the 90w-140 helpes quiet down cheepo lockers and really keeps the temp down and helps with noise/vibration.
    Doubt it would add much to a 4 runner diff, I would use the lighter wt. especially with the temps you guys have.
  6. Romer
    11,058
    2,677
    Sep 14, 2003
    Thanks. Maybe I'll try the heaver weight in the 40 with the Aussie in the rear when it needs changing.
    You still coming out this way in a few weeks?
  7. Bryan E.
    Bryan E.
    402
    1
    Aug 22, 2003
    Ken, None of the dealers in my area carry the gear oils so where's the best place to mail order this? How much will I need for the transfer case? Redline's site say's about the 75-90 ..."It contains friction modifier which is recommended for limited-slip units." , then I looked at the 75-90NS and it said it didn't have friction modifiers in it. Does our 80 series transfer case need a friction modifier or not??
    Thanks,
  8. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    no friction modifier should be needed, friction modifiers are for clutches found in Positraction rear ends, our lockers are positive locking steel toothed with no clutches, there are also no clutches in the transfer case.
    but it seams they recomend friction modifiers in normal rear ends for some reason
  9. IdahoDoug
    IdahoDoug
    8,864
    272
    Aug 9, 2003
    R - I really think this belongs in chat, don'cha think? Right under the vasectomy thread, eh? Heh. Sick bastij
    DougM
  10. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    Doug, at first I was quite :confused: by your post.
    So does the wife have junk in her trunk? You really should take the stuff out the extra weight makes the motor work harder and reduces gas mileage.
    Please disregard my post #6 above seams RedLine wants you to use their stuff with the FM in our app witch is counter to common wisdom. hopefully somebody knows more.
    BTW according to Redlines web site no one within 50 miles of me sells thier gear oil.
  11. Romer
    11,058
    2,677
    Sep 14, 2003
    http://www.hrpworld.com/index.cfm?form_cat_id=387&action=category Don't know anything about them or if its the best price. I almost ordered from them before I found it locally.
    Our rigs don't need the zinc modifier. Reading posts from Cary here and others on bobistheoilguy.com these modifiers won't hurt anything in our rigs and non friction function could help a little. I also talked to the guy at the shop and he agreed. He said if I had power traction or limited slip, then the Friction stuff is required.
  12. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    That is the confusing part, our rigs should not need the modifier but the stuff without the modifier is the NS stuff that you did not use, so you have the modifier
    seams Redline is recomending the stuff with the modifier in most differentials with clutches or not so you got the stuff they recomend
    as for why I dont know :confused:
    75W90 the stuff you used
    75W90 NS the stuff without the modifier.
