Red Line In tank fuel pump DIY kit 40/60 series (1 Viewer)
Colo Spgs Colorado
Need Your EFI Sniper fuel pump in the tank? Here is our DIY kit! We also install these into new OEM tanks or Your tank if decide to go that route. We copied the 62 series OEM tank hanger boss for this universal design. It uses the OEM rubber gasket and utilizes an-6 fittings and an upper machined 6061 aluminum top. Allowing this to be used to convert your 60 series tank, 40 series or aftermarket rear aux tank! Comes with all the tid bits to do it right. I.E. fuel submersible wire, fuel line and so forth! 370.98$
Red Line In Tank Pump Kit
Justin
