Tried searching but couldn't find anything with this unique scenario...
'84 FJ60, 2F, 286k miles. Just bought the 60 a couple weeks ago.
Before carb rebuild it would run perfectly fine at times, then all of a sudden it would stall. Start right back up, run for 1-2 seconds, then stall. Start right up, then stall. Rinse and repeat. Throttle input or choke did not matter. New fuel pump, fuel filter, air filter, and spark plugs (appear to be OEM parts installed by PO's mechanic). It would do this when engine was at temp or cold.
Rebuilt carb (by me) with kit from Cruiser Outfitters. I feel pretty good about everything going back together well. I used Pinhead's videos and the FSM. I also replaced all the vac hoses on the driver's side of the engine with the 3mm and 5mm silicone hoses while the carb was out. Still need to do passenger side hoses...
Starts up and runs great with choke (around 2k RPM), will stay running great at lower engine speeds 700-800 RPM) all the way to last click of the choke, but without choke it stalls. I can keep it running with throttle input (without choke) down to about 700ish RPM.
Fuel bowl level looks good through sight glass--I adjusted float per FSM.
Idle mixture screw turned all the way in, then backed out 1.75 turns.
Tried to find any vac leaks using carb/brake cleaner. Only place I got any increase in RPM was around the primary throttle shaft on front side of carb. Is there any more scientific way to check for vac leaks with a vac gauge? I believe I may have a gauge...if not, I could buy one...
Sounds like it may have an exhaust manifold leak...getting the indicative little "tick tick tick"... Add it to the list of "to do's"...
Fuel cut solenoid didn't give me any problems before carb rebuild...could it be a freak coincidence that it failed at the same time as rebuild or could I have damaged it somehow?
Thanks in advance for any help!
Photo just for interest...
