rebuilt carb blues FJ 60 1982
san diego,ca
JUST INSTALLED REFURFIBISHED CARB, OLD TANK USED AND GOT IT DIRTY, CHANGED TANK TO A BRAND NEW ONE. CARB TAKEN OFF AND CLEANED BY MECHANIC, REINSTALLED. WORKED FINE. PULL CHOKE PUMP TWICE AND FIRES AT ONCE, ONCE HEATS I CLOSE CHOKE AS USUAL AND DRIVE IT AROUND. AFTER A FEW MILES RPM'S DROP AND SHUTS ENGINE OFF...HAD TO RUN CAR WITH FULLY OPEN CHOKE AT 1.5 RPMS. WHAT CAN THE ISSUE BE?. HAPPENS EVERY DAY. STARTS FINE, WORKS FINE FOR QUITE A BIT AND THEN ALL REPEATS ITSELF? PLEASE TIPS ON WHAT COULD BE PLEASE?
WHY ARE WE YELLING?! In all seriousness, when I had to drive around with the choke all the way out it was because I had a ton of vacuum leaks (making it run super lean I guess). I replaced all of the hoses and problem went away.
