I've started a couple of threads this week with random questions trying to diagnose issues, but I thought I'd try one last time before I call in the professionals (anybody know a good professional close to Little Rock AR)? My rebuilt engine is going down hill.......
I had my 2F (11/78) recently rebuilt. I replaced all accessories on the engine (fuel pump, water pump, thermostat, hoses, fuel lines, new pcv valve and grommet, new vacuum hoses). I installed a Performance HEI distributor with Live Wires with a relay to power the distributor. I had Mark - 65swb45 - rebuild my carb (along with my steering box).
I started the break-in process Friday. Prior to turning the key I primed the oil system (and confirmed oil pressure) and primed the new fuel lines and carb. I did have initial trouble getting it to start due to a timing issue. I got that resolved and ran the engine for 25 minutes between 1500 and 2200 rpms with vacuum gauge showing around 20. I thought it sounded great and it ran very smooth. I let it cool down, changed the oil filter, and topped off the oil (I'm using break-in oil from the rebuilder who also recommended the oil filter change). The engine won't idle without choke (I can hardly get idle below 1000) with vacuum showing about 16. Classic vacuum leak symptoms (according to my many hours of mud reading). My idle solenoid is working. Engine is desmogged, so not many potential vacuum leak locations. I tried propane and carb cleaner to find a leak and couldn't find anything. I built a smoke machine and tried to pressurize intake through the top of the carb and tons of smoke leaked out of my carb (should this happen?). I removed carb, bolted a wood plate with gaskets to cover carb manifold opening and redid smoke test, but didn't get any smoke from manifold gasket (I could only get smoke to come out around the wood plate). I polished my intake manifold during the rebuild, so I'm sure there are no cracks. The manifolds were NOT surfaced. I can't find a machine shop willing to do it, so I used a Remflex gasket. I happen to have a never used troll hole carb. I installed that carb as a test, but it also needed choke to idle. I did drive the 40 about 35 miles this weekend and it ran great expect for the high idle. However, after switching the carbs and trying to find the vacuum leak the engine is NOT running smooth any longer. I tried to drive it again last night and I have a lot of hesitation when I give it gas (and I did notice gas seeping out of the carb on the side facing the block after trying to drive it). I rechecked the timing last night and I think it was about 12 btdc at around 1000 rpms. I think a couple of days ago it was showing around 18 btdc at around 1550 rpms (I don't remember exactly). At higher rpms (1500 plus) the vacuum is very steady at 20. When idling around 1000 it's 15/16 with a little movement of the needle. When I give the accelerator a good bump vacuum drops to around 4/5 and then jumps up to maybe 22...which I've read sounds normal.
I know this sounds like classic vacuum leak but Is 15/16 on the vacuum gauge really not enough to pull fuel from the idle circuit? Would a vacuum leak at the manifold of 4 to 5 hg be hard to detect? If I pull the manifold off do you think a visual inspection of the gasket would show signs of a vacuum leak?
