Rebuilding Front differential
Discussion in '40- & 55-Series Tech' started by nocents, Feb 21, 2004.
  1. nocents
    nocents SILVER Star
    475
    9
    Oct 27, 2003
    Starting to rebuild the axles and differential on my 71 FJ40. Got everything apart except for removal of the front differential fron the axle housing. The rear was easy in that you can remove the rear cover and then knock the rest apart. The front has me puzzled, tried light hammer taps, it won't break apart....Any tips
    thanks in advance
    nocents
  2. woody
    woody unhelpful spotter Staff Member Admin
    10,831
    Media:
    317
    Albums:
    8
    2,577
    Jan 15, 2002
    Toquerville UT
    do you have the front birfields/inner axles out?
    If yes, then it's just being stubborn. Put a floor jack under the pinion and apply pressure, carefully...it will crack loose.
  3. nocents
    nocents SILVER Star
    475
    9
    Oct 27, 2003
    The axle and knuckles are all torn down. The axle is not mounted to the frame as I am doing a complete frame up restoration... I guess I'll try a bigger hammer.
