Have any of you rebuilt these factory soft doors?
Do you know what the panel is originally made of?
thanks
Destin
thanks
Destin
same material as the factory soft top.. some canvas and some vinyl.
wasn't a thread on mud, it was a writeup in toyota trails
I have a pair that need rebuilding that I've put on the backburner. However, I do have one new OEM door (still has plastic protecting the sliding window) to use as a guide in addition to that excellent TT article. PM me if you ever need any pics - now if I could only find another new to go with it.
Its actually very easy to rebuild these doors...the retaining channel (that holds the rummer door seal) holds the canvas/vinyl in place holds the canvas
Wrap the canvas on the top holding plate...it has tabs that fold over onto the door frame.
then pull bottom down and secure in the middle of the bottom of the door with the screw...then work your way around on both sides.
really not that hard just a bit time consuming.
then the rubber goes into the channel...sooo...if you are replacing the channel retaining screws...you need to use a wood type screw...very small ...it needs to be a countersunk screw that has the thread go all the way down the shank...I think i found some at True Value.
Alil soap on the channel and rubber it will slide thru nicely...if you use a lube like spray sylicone...if it gets on the canvas it will be there for a long time...like getting a oil stain on your jeans.
I replaced one plastic window with a piece of plexiglass the same thickness...workes really well
a few years ago the rubber for the door channel was avail at toyota...you might want to check w/toyota or CDan
part # 68161-60020 FJ40..TP; FOR CANVAS DOOR
the 1/4 window rubber is no longer avail...i know that for sure
Do you happen to know the url/link?
Thanks, sorry for the hassle.
Destin
no actual link, it was published in the toyota trails mag a few years ago. sorry
ok cool
I did try to search but found nothing, now it makes sense
Thanks woman!
