Okay I have a 2000 LC with 160k+ miles on it. When I bought it, I know the rear wiper fluid was working great. But since then I had some work done on the car replacing the battery, and some work done on the front left suspension. The ball joints were replaced. But since this work, I noticed the rear Wiper Fluid not working. I thought it was the rear wiper fluid fuse. But it doesnt look like the 2000 LC's come with one. At least not when I checked in the engine fuse box and the fuse box under the drivers leg side. I see wiper fluid but that looks like the front part which is good.
I wondered if my mechanic forgot to put the rear wiperfluid tube back on after doing work on the suspension. I have verified that I have lots of wiper fluid so thats not the issue. Also I believe the same Wiper fluid reservoir tank is used for both the front and back wiper fluids.
When I test the back fluid I do not see any water coming out. I just dont see anything coming out. Could it just be clogged? or do I need to trace the fluid line and see if its disconnected or could it be a fuse that I am missing?
Btw the front wiper fluid works as expected. TIA
