ok...so my window was working perfectly, sometimes got hung up when rolling it up due to worn out window channels...anyway, rolled it down the other day ( dash switch and key switch work fine ) and now it won't go up. I have bypassed the safety swith. Anyway, the glass seems free in the window channels on each side, I took the back cover off and tried the switch while pulling up on the window, in case it just needed a helping hand. That did not help. While I have the back door down, I hold the key in the 'UP' position on the key switch and hear a sporadic muffled groaning/creaking sound coming from the bottom of the door. I can hold the key for as long as I want to and the sound comes and goes. I can see the window motor and gear, and that is not budging when I turn the key. The plastic gear seems to be fine. When I initially turn the key in either direction, I can feel a slight 'click' like the motor is trying to work, but again there is NO movement of the plastic gear or worm gear. I'm guessing the motor is bad, but I'm not convinced. Anyway, now that the window is all the way down, I can't get to anything to work on it. I did a search and found some mention of some C clips that I can get off and move the window manually...I think I found the clips but I am worried about getting things apart/broken and then the window still won't move. The piece that runs the length of the window that holds it to the regulator is definatley fused to the window. Any tips?
Thanks
Ben
Thanks
Ben
