New to the forum and cruiser ownership, but have used it so many times to solve issues on the 80 - thanks! Thought I'd try to return the favour and post my experience in case it helps someone in the future.
My FZJ80's rear indicators/turn signals stopped working intermittently, both the standard taillight housing bulbs and LEDs on the aftermarket rear bar. RHS at first but then occasionally LHS. Following advice in a few threads here I checked the bulbs, fuses, flasher relay, hazard switch (had recently removed the dash to replace radio so could have been loose when replaced), cleaned/checked the earth points in the passenger and driver's footwells (behind plastic kick panels that run back along the sill) and under the tailgate as well as checking the trailer hitch wiring and earth - with no luck.
Cracked out the wiring diagram (first time for me), and worked from behind the front turn signals backwards given everything at the front was working fine. Got lucky and after disconnecting the first harness connection point in the LHS footwell (labelled ID2 in the screengrab below) and testing the turn signal pins (20 and 21) with a multimeter (positive probe to the pin on the male side of the connector, negative to earth, beepy continuity setting) to confirm they were working with the respective indicators switched on, popped the connector back together and bingo everything works fine. Must have come loose over some rough roads - hate to think what else was not getting a good connection.
For anyone interested that is the connector labelled ID2 in the wiring manual located in the LHS footwell. Big flat 22 pin connector near the firewall. If that hadn't worked I would have continued backwards to the BQ1 connector and so on until the beeps stopped. Hope that helps, took me 3 days to work out - I'm no bush mechanic that's for sure.
Relevant part of the diagram (pg 87)
ID2 Location (its in the left footwell whether your vehicle is LHD or RHD):
ID2 layout, turn signal positives are 20 and 21, male side is towards the battery.
