Rear tube bumper design contest/help
Bay Area
I recently stripped off the rear bumper of my 94 80 and am wondering if any of the design gurus out there can help with ideas for a simple/light/tube rear bumper.
design parameters:
--rear crossmember will be removed and frame rails chopped ala 4x4labs.
--rear quarters can stay or get facelift
--must have hitch
--high clearance
--simple - light-- strong
-- wraparound corners
--currently rig has fender flares- may consider without
Difficulties-- what to do with frame ends(holes)/ elegant way to tie in to frame ends as well as sides for corners / hitch receiver incorporation
Top idea wins................
a badass Cargo net
heres mine, I would not do the drop down again, but clearance wise it rocks
Rear cross member is removed and bumper boxes the frame rails
Here is mine. I have recently taken off my spare tire mount and have switched to the one that IPOR sells as a weld on option.
http://www.ironpigoffroad.com/fab/fabimg/tire-mount.jpg
I havent put it back on yet as i am considering adding a ladder at the same time.
https://forum.ih8mud.com/**-ih8mud-com-vendor-marketplace-**/185654-need-ladder-your-60-a.html
Here it is as it was built. I will prolly have it 2.0 in a couple weeks and will keep you up to date if you would like.
I chopped about 7 inches off my frame, also chopped my rear quarter panels. I like the design ALOT. I dont think it looks as refined as a slee of 4x4 labs wich i am kind of saying as a bad thing cause those look nice. But i do like that it is lite and strong and has great clearances.
hope that helps.
hope that helps.
NOW THATS A SWEET 80 BUMPER!
kewl Sickboy! a few questions-
do you have any closeups of how far back its cut and how the tubes connect to the frame rails on the rear?
what size dom did you use on the main tube? same for other tubes? wings etc.
also curious what height the main tube is at---ie- toward the middle or top or above the frame?
If you happen to have any closeups of these various connection points with the frame--that would be kewl.
thanks,Tim
hope that helps.
That is a sick design. There are not many 80 rear bumpers that I like, but that one is bad ass. :hillbilly:
Here's how you do this and keep the hitch.
1) Cut the frame back to close to the body mounts - how far you cut depends on how much you want it to extend back behind the body in regards to a tire mount, etc.
2) Weld in a 3/4" block with a 45% angle extending out beyond the original frame rails.
3) Cut a hole a 3/8" sheet for the hitch and weld the sheet on the new 45 degree angle on the mounts you have created.
4) Cut your hitch at 45 degrees, weld it flush to the 3/8" sheet, and then triangulate behind the new "bumper" back to the frame. I am using the Slee receiver to do this as it already has the triangulation points.
5) From the top of the new 45 degree mount you created cut a hole mount for 2" tube. Wrap the tube around and bend it into the body and upwards one past the frame, tucking it into the top of where the plastic flare used to be.
6) Run a second brace from the frame to this upper wrap (you may need to trim the body).
7) Design a tire carrier if needed (mine will stay on the roof).
Jim, you ready to get started? :grinpimp:
it would be super easy to add a hitch to mine. I have thought about it but i just havent had a need. I would never want a tire on my roof. I honestly cant handle a 37 myselft. Sure rolling it around the garage or lifting it an inch when the jack is just right, but a trail fix? if i was alone i would be in a bad way trying to egt it off th roof.
Make sure you build a swing out. They are not that hard to do especially with options like iron pigs for 90 bucks.
That's a good point on a 37" tire. I can get the 35 up there, but that's a max. Being 6'2" helps :D
I use my hatch all the time and I hate having to deal with a tire carrier. What I think I am going to do is buy a 35x10.5x16 SSR spare once it is time to get new tires. These are the same diameter as my trxus MT's, but the narrower tire will fit behind the 3rd row of seats if I want to store it there, or will have a lower profile up top.
I dig your bumper BTW, it's been my baseline modeling idea ever since I first saw it.
Also Sickboy, do you feel its possible to have the main wraparound tube a bit closer (say where the swingout bar is) to the body? or did you want to insure the swingout is fully recessed relative to the rear of the main tube?
kewl TN! whats your plan for wings? or none.
Thanks bugs...The white on the bumper is going to be cut off. The angle cut will allow me to weld in plate steel at the same angle and pitch as the rear quarter panel behind what used to be the OEM bumper. I will then tack a couple support pieces to the frame underneath and one inside the wheel well to the frame to give it support in the front.
I also plan to eventually weld some quarterpanel tubing in (once I get a bender) to protect the rear end. The combination of the sliders and bumper will also give me anchor points for a exo around the fenders.
I have an idea in my head of what Im wanting to do, but definitely doing it all by trial and error!!!
That is the problem with a swingout - you have to take it all the way past the edge of the hatch, and that pulls the edge of the bumper away from the body.
If you don't recess it a bit, you end up with the hinge exposed. This forces you into a boxy design even with tube. Without that carrier, you could angle inwards from the frame and then around the corner, leaving a stepping point while pulling the typical hit point (the corner) in.
I'm debating the need to cut the quarters - the frame hangs so low anyway I'm not sure it's worth it rather than running the main tube tucked into the "notch" where the plastic used to be and then a lower tube that is just frame rail and bent right under the seam weld - then connect the two tubes and you've created side protection without needing a hoop that extends out from the body, which is a look that I do not like.
You could say that not cutting means less clearance, but as long as it will slide and is at frame height I'm not sure you lose anything. This is how the stamped bumpers work, and I've never seen anybody hang on one - you just slide off. The key is weight and cost in terms of going with tube.
would people suggest larger diameter main tube versus smaller on the sides? or same diam. everywhere???
2" or larger dom?
sickboy- what weight would you guess yours is total with carrier?
i imagine its 125 pounds, i have never wieghed it but i can take it on and off myself. i loaded it into my 100 to take it to get sand blasted.
The tire carrier is tucked up as close as possible. The only think i think that could have been "tucked in more would be my side wings but i actually am cool with them because the doo keep me off of rocks and trees nicely.
I dont see any reason to go bigger than 2 inch? that is what a lot crawler buggy chassis are bulit out of. Mine is branced nicely on the outside frame so i dont see it going anywhere.
I can see what yoru saying about my main hoop being under where my tire carrier is, but if you actually see mine, i have a hard time thinking this would be an Issue. My thinking on this was that i didnt want to ever catch my tire carrier on anything as it would get pushed into my rig.
Do you really think it is that heavy? My front bumper has about 16 feet of tube (2" .120 wall) plus the 3/4" thick mount brackets we welded into the frame and a winch plate and lower frame "slider" plate, and if that thing is 60 lbs I'd be surprised.
I doubt you will find anybody bending more than 2" tube in the offroad market - plenty of fabricators stay at 1.75".
The thing about tube wall thickness, and the reason you see .120 wall so heavily used IMO, is that tube will bend to a surprising degree and then spring back. The reason for using a heavier gauge would be if thought you were going to dent the tube itself rather than the "macro" movement, and to do that you'd need to get into the practice of ramming sharp corners pretty hard.
This even goes down into the DOM vs. HREW argument. If both will bend and spring back, and it's just a bumper (not a cage), is DOM worth the spend over HREW? Maybe not. My front is HREW and the rear will be the same when I have it built.
125lbs is pretty impressive when you think that losing the stock hitch is about 40lbs and losing the rear crossmember is another 30-40......so a net gain of 50lbs give or take including carrier.......sheeesh-- me like.
You say you can remove it---how is it connected to the frame? any shots of those areas handy?
