Hey all - long time user of this forum, but first thread...
my local indy just replaced the suspension on my 2001 LX470. Took out the AHC and replaced with OEM Toyota shocks, rear springs (used, pink dot on left side, green on right) and OEM Torsion Bars. All purchased from Christo at Slee Offroad
When I picked up my truck and got it back to my house, I could see the rear was not level, the left (driver side) is about a half inch higher than the right. Measurements from fender arch to wheel cap center:
FL 19.75"
FR 19.75"
RL 20.25"
RR 19.75"
visually the truck appears to have proper rake, although the measurements above do not clearly show that. I know the left spring is ~12mm higher than the right spring to account for gas tank and driver, but not sure if I should be concerned
I have not had an alignment performed after the suspension swap. Any ideas on whether an alignment will correct the slight lean from L to R in the rear? would TB adjustments correct it? possible I got a slightly sagging used spring? Or dont worry about it.
Looking for ideas. Thanks!
FL 19.75"
FR 19.75"
RL 20.25"
RR 19.75"
