rear steer (1 Viewer)
I've got to front rokwell axles on my fj40. where can I find the rear steer joy stick and other accesories? i tried doing a search but no luck. thanks
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
I have a spare front Mini axle, would that be a good rear steer axle???
Texican
s-Moderator
Bonham Tx.
Yes but you would have to "Butch" every event to avoid "Macing" the trails....... :D :D :D
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
DHONDAGOD said:
ball and claw! ball and claw!!! :bounce:
chris :cool:
SWEET!!!!!
I forgot about those....
Now, where did I find a set...
Hmmm...
:flipoff2:
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
fj40charles said:
It is the peferct axle for a 2F motor..
What is this 2F that you speak of???
:confused:
I have to add some tech to this hijack. Give Scott at rockstomper.com a call. I know he deals with hydraulic steering stuff all the time and is a straight shooter.
Mankato, MN
redneckrokcruzer said:
I've got to front rokwell axles on my fj40. where can I find the rear steer joy stick and other accessories? i tried doing a search but no luck. thanks
All of my stuff I get through Sean at Performance Offroad Systems. I believe he is a vendor on Pirate4x4.com and his contact info is in the hydro steering Tech article on Pirate.
I am running (once plumbed) a electric joystick controlling a solenoid to activate the rear ram. I also have a priority flow divider in the system. Sean can set you up with however you want the system to work. I highly recommend him.
John at stazworks is great to work with two, and I believe Sean and John still work together on the hydro systems.
You might drop Jeremiah an email at info@proffittscruisers.com to ask him the specs on what he uses, works well w/ the 49's.
Northern Hydraulics= $$$CHEAP$$$ ...'course I should refer to it as "inexpensive", 'cuz it works extremely well :cheers:
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
