About a month ago I heard loud noises coming from the rear. I crawled under and saw the cross member/shock bar had rusted through on both sides. I read a lot of posts and finally had a plan.
A PO used a 2 inch pipe/tube and a 1.5 inch pipe/tube to piece the stock shock bar back after it rusted.
I decided to go with a smaller 1/5 inch pipe that was almost completely solid. I fabbed a couple of shock months and completed the repair this past weekend. Here are some photos.
I welded the passenger side mount prior to sliding the pipe, from underneath, through the preexisting holes in the frames and then welded the drivers side. The bolt is 2 inches above the bar so the measurements are very close to the stock position of the shocks.
This process wasn't really difficult but it was time consuming.
