I was doing some work to the Cruiser last weekend and found two things I have questions about...
First, behind the rear left quarter panel, there is a wire that has been tapped into with a Scotch Lok connector. I should investigate this further, but it's not a resistor of any kind and I was wondering if anyone else has this tap.
Next, behind the right rear quarter panel, there is a small black plastic box with two little blocks (relays of some kind?) that are revealed if the cover to this box is removed. These blocks are secured to the box with lots of plastic... I hear them click when I brake (brake lights) and when I turn on my turn signals, along with the relay behind the driver's side kick panel. This box is Toyota branded. Does anyone know what this is?
Also, additional question, if I have 22-16 AWG wire and I use a 14-16 AWG wire tap to tap into it, will there be any problems? (unrelated to first question)
Thanks in advance...
