My rear right hand side parking brake seems to be seized, it will pull on if you pull the cable that is attached to the lever on the hub, but it will not go back, it will return if you hit it lightly with a hammer a few times, is this a general trait of the LC and what are normally the cures for it?
The cure is to rebuild the brakes and ensure that there is adequate lubrication. No, it is not "normal" - like any drum brake it needs ocassional servicing.
Time for you to can cruiserdan to order some parts.
Mine has been seized up for about a year. I ordered new shoes from Cruiser Dan (received everything in good order and very promptly--THANKS DAN). In speaking on the phone with him, he shed some light on much of the problems that seem to be similar. He also explained that is difficult to diagnose and order parts ahead of time without tearing everything down, b/c there can be several different issues. Anyway, I am going to do new pads, some seals, bleed entire system, etc. I figured this would be as good as time as any to repair the PB but quickly realized that I may have to slap things back together and order some additional parts. For me, I know that the shoes, at least on the right side are gonna be toast.
Good luck and let us know how it goes--- hopefully just some new shoes and good lubrication
remove wheel, drum and the ruber boot on the relay arm and add a little degreaser on the pivot and some wiggle wiggle wack wack will fix the seized arm. it did for my north east beast. i thought i needed pads but they were fine. then just re-adjust the cable and i bet it will be good. and at that point you will have inspected the pads.
