Liam, do you mean if they properly indexed them prior to install?
yes...that is what i meant. If there were improperly indexed would that cut the amount you would be able to lift it?Liam, do you mean if they properly indexed them prior to install?
jesus, now i am all confused.....Possibly. Crawl under your rig with a light and take a look to see how many threads you have remaining on the t-bar adjusters (check each side they may be different). Generally you will get about 1/8" lift with each full rotation of the adjuster bolt (just an approximation).
Not to stir the pot...oh well I guess I will anyway...I've had 865, 866, 863, 864 and a set of Slee custom springs on my 100 since I started modding it. Based upon no steel rear bumper, and little to no cargo I would recommend the 865's...as Campfire and Shotts stated this results in a nice ride and nice ride height given your rig configuration. Otherwise it will be a bit on the stink bug side with 863's. Whether or not you can find them used is another issue.
I have an ARB commercial bar, M8 winch, OME t-bars, and 863's. My truck is level and there's a bit more to go on the t-bars.
NOT A CHANCE!
The front in the pic below is MAXED out...2.75" up.
The back has 863's AND a huge steel bumper with tire and jack....and it's NOT level. Take that load off and you have a '74 Camaro that's jacked up in the back.
PM sent!!Liam,
Go with Spresso's and Schott's advice and get the 865 springs. You won't be disapointed. Had them on my truck before I added the slee rear bumper. Loved the ride.
I have a used set sitting in the garage since I am now running 866 springs to handle the extra weight of the rear bumper.
PM me if you are interested.
so which are the tallest? 863's, then 864's...etc??look like this when my truck in not loaded
Well, once again, you're right. Assuming the fender arches are in line, I measured front and rear. Front is 37 7/8", rear is 38 1/8". I have a QUARTER INCH of rake! That's HUGE! If you need a reference of how much that it Shotts, just look down at your . . . . well, nevermind.
Oh, and 3/4" left on the t-bar anchor bolts.
If those measurements were identical you'd still have rake. To level the truck the front number must be higher.
