Rear Lift Gate Carbon Monoxide Issues
C6H12O6
Beaverton, Oregon
I'm needing to carry some long boards home from the lumber yard, and I'm curious about CO issues with driving with the rear lift gate up. I'm assuming that driving with the back open would pull exhaust fumes into the rig at unacceptable levels. Would a short trip with the windows/sunroof down to push a little air through front to back be ok? I'm talking 10 minutes of side roads max.
I guess the worst that could happen would be that I'd drift off to sleep and veer into oncoming traffic. Very peaceful.
NorCalDoug
problems solved daily...
uhhhh...duh...Northern CA
you'll be fine.
keep your windows open a bit to get some airflow, if you're really worried about it.
since you'll be moving, the CO will not creep into the cabin. CO would only be a concern if you were stationary...say, sleeping inside with the engine running and the rear hatch open...and even then, it shouldn't be much of a concern.
Anyone know if CO is heavier/lighter than air? Been wondering about that one... Should a CO detector be placed high (on the ceiling) or low (along the baseboard)?
Austin, TX
Do NOT open your windows. That will only make it easier for exhaust to enter (in the back... out the front windows, get it?). Keep driver/passenger windows closed and turn on the AC/heat/vent to force air in the front/out the back.
Jeez, just read the operator's manual... it's all in there.
NorCalDoug
dude's going to be moving...on the road...
seriously, CO doesn't come looking for you...it's not going to grab onto your rig and crawl it's way into your lungs...
:rolleyes:
Trumansburg, New York
CO is about the same density of mixed air. It is usually the product of combustion (in this part of the atmosphere at least) so it's usually hotter so that's why it would rise. Also, it'd move due to convection and diffusion as well so you're safe at the levels you could get under those conditions.
didn't you see Cheech and Chong's demo of how to suffocate in a car...
MN physically, MI spiritually
CO detectors are pluged in or instaled at the lowest point in the room as in an electrical outlet. CO is heavier than air as well as CO2. Didn' you guys see CSI's cheerleader episode?
NorCalDoug
yeah, I saw a couple CSI episodes dealing with CO2 -- don't recall the cheerleader episode :D
I knew that CO2 is heavier than air -- did a cool experiment in HS; filled a beaker with CO2 and "poured" it down a ramp that had small lit candles on it. It was cool to watch the candles go out one by one.
Wasn't sure of CO's weight though...it's missing that oxygen molocule y'know...so it's lighter than CO2.
I'm no scientist, but...oh, wait, I am. So roughly 78.1% of the atmosphere is Nitrogen, 20.9% Oxygen, the remaining ~1% is usually dominated by Argon, water vapor and carbon dioxide.
On the periodic chart Oxygen is more dense than Nitrogen followed by Carbon (least dense).
Do the stoichiometry :grinpimp:
Or trust a TV show :flipoff2:
C6H12O6
Beaverton, Oregon
Don't mean to split hairs, Mr. Scientist, but the periodic table says nothing of the density of the elements, which varies with states of matter, temperature, pressure, etc.
At standard temperature and pressure, the density of CO is very close to atmospheric air. Even still, the idea that less dense gases will form a layer at the top of the space they're in is not true. Even if the more dense gas was introduced in a controlled manner at the bottom of the room, like on CSI, gas will eventually disperse to fill the volume of its container, regardless of density. The motion of the air inside a vehicle with the windows open and the rear gate down will only hasten the mixing of the gases.
As to the car moving, I would think that a cruiser with the rear gates open would allow for significant draft into the rear of the vehicle, even if moving. Maybe even more at speed. Remember the cowl induction on the old muscle cars?
CreeperSleeper
Cascade Cruisers
Forest Grove, OR
Steve- I highly doubt you will have a problem. I used to ride in the back of my dad's truck with the canopy door open. It hazen't screowed mee up two much.
The Rock
I'm not sure about an 80....BUT
I drove my 60 4 hours home when I bought it in Atlanta from InfoJunky. Many will remember some kids shot out the back glass with a slingshot...
He taped it up for me, and with windows down, the fumes were still pulled in, the whole way home, and for a few days until I had the glass installed.
10 minutes? No worries.
I did the same with a fj60. It was horrible with the windows down and slightly less horrible with the windows up.
MoGas
Central Scrutinizer
GOLD Star
Air Mobile
Page 113 1996 Toyota Land Cruiser Owners Manual:
Keep the back door closed while
driving. An open or unsealed back
door may cause exhaust gases to
be drawn into the vehicle. If you
must drive with the back door
open to accommodate a large object,
close the windows, open all
the instrument panel vents and
have the heating or cooling system
deliver fresh air into the vehicle
by turning the fan to high
speed with the air intake control
set at the OUTSIDE AIR position.
Hope this helps,
Dave
FJBen
West
Sheesh, if you drive a 55, you get used to that with the rear window rolled down...at some point you actually think you are driving the speed limit.
MoJ
Moderator
Before buying a trailer I hauled lumber that way many times. You have nothing to worry about worry about worry about worry about *smack* You'll be fine.
Queensland and California
Hope this helps,
Dave
That was always my protocol for hauling stuff home from Home Depot.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
