OKMike
Two quick ones. 77 FJ 40 with semi-floating rear axle:
1. Just pulled the axle shafts and seals. Obviously there is a special tool required to pull the rear wheel bearing. FSM shows some goofy Toyota tool. Any suggestions on what I might be able to buy or rig up at home? UPDATE--I got a rear axle bearing puller kit from Amazon for $26.00. Worked like a charm with my 10 lb 5/8 thread slide hammer. Easy peazy.
2. The lugs appear to be pressed onto the axle flange and there is an old rotting paper gasket between the sheet meal cover peice and the back of the flange. Rebuild kit came with replacement gaskets. How do I get the lugs out to replace the gasket? Will I need a shop press? UPDATE--my trusty Harbor Freight Ball Joint Press worked great for pressing these out. Was able to clean them up run a quick die over the threads and repress them in. The old cover things were beat to hell, Bought two new ones from SOR.
Thanks!
Thanks!
