Thank you.
So it should be 87245-60420 which is for 80 series trucks without rear heat.
Different number I have not seen that hose and cannot comment on its fit on an US 80
Thank you.
Thank you.
87245-60310 (87246A) HOSE, HEATER WATER, OUTLET A (without rear heater) Substitutes for 87245-60340 (87246B) HOSE, HEATER WATER, OUTLET B (PS Hose to the heater pipe back at the firewall)
Not the correct part number. Not even close.
This one fits build-date 08/'92-01/'98 Asian and Middle Eastern FZJ80's without rear heat. (diagram)
It's available here for about $30.
Or, I just used a molded 5/8" hose that I cut to fit like this one for $5 and retained the metal u-pipe.
Oh well. Too bad @LandCruiserPhil won't share his knowledge with the community. I'd chase it down further but I already bypassed the rear heater.Not the correct part number. Not even close.
Not familiar with any of the numbers above, what it fits like or looks like.
The one I offer from Gates is $27 in stock and Free shipping (also available in Toyota) The fit is perfect and looks factory.
The least costly method noted above pictured below has more connections with a greater chance of failure and looks non factory
The good is you now have more options to have the look you want.![]()
