Hey folks, long time listener, first time caller here! Sorry, couldn't help it....
It's time for me to do some rust mitigation on the infamous rust spot at the bottom of the upper rear hatch on my '03. So far I don't see any rust coming through on the pinch weld, but I see some surface rust around the weep holes and latch handle. Since this appears most commonly due to a leaky upper tail light I am assuming there is more rust inside than what I see outside. My plan (after sealing the light) is to grind it all down to metal, treat with rust converter, then probably a low-budget DIY paint job. And possibly a healthy dose of fluid film on the inside afterwards. That is unless I grind away to nothing left It's a NW car and the rust doesn't look too heavy so far, so I'm hoping that by dealing with it now I can nurse the hatch along for a while longer.
Which leads me to the actual question. I'm guessing (hoping?) that if I remove the interior panels I will be able to reach down inside to sand from above and also treat/etc. Does anyone have tips on removing the panel(s)? I've done enough of this kind of stuff in the past that I'm terrified of the brittle, hard to replace plastic clips that you don't know are there until they're already broken. Any tips on where to start the removal or what tricky clips to look out for would be *much* appreciated. I don't have the FSM, but it sounds like the FSM has instructions for some panel removals. If this is covered in the FSM could I trouble anyone to post a screen shot of the instructions?
I searched the forum as well as youtube, but didn't find anything that exactly answered my question. If this is already documented somewhere (I'm sure it is), please just point me to it.
Thanks!
Thanks!
