Rear disk brakes
Fireman
Iowa Park. TX
Brackets from Poser
$65
Parts from Rockauto.com
(rotors) 1990 CHEVROLET K1500 PICKUP 5.0L 305cid V8 TBI (H)
ALLSAFE 5977RGS $ 13.49 $ 0.00 2 $ 26.98
(Calipers)1978 CHEVROLET MONTE CARLO 5.0L 305cid V8 2BBL (U)
A1 CARDONE 18-4071 $ 10.79 $ 10.00 1 $ 20.79
A1 CARDONE 18-4072 $ 10.79 $ 10.00 1 $ 20.79
(pads)RAYBESTOS RR-D154M $ 11.40 $ 0.00 1 $ 11.40
(Brake lines)1983 NISSAN 200SX 2.2L 2187cc L4 MFI (R) [Z22E]
RAYBESTOS BH38149 $ 10.08 $ 0.00 2 $ 20.16
Shipping $ 25.78
Order Total $ 125.90
2 bolts to hold the brake lines to the calipers from local dealer
PN 88891786
$12.00
About $205 and don't have to jack adjusting the rear brakes anymore and no more leaky wheel cylinders! :bounce: :bounce2: :flamingo:
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
osagecruiser said:
any pics of the install?..
osagcruiser
He will have his brackets next week.... ;)
Info added to the FAQ!
Thanks David!
:beer: :beer: :beer:
Hey, and find this thread, and add any more info to it as the install progresses, so it will stay in the FAQ! :)
cruiserjunktion
Cruiserjunktion@gmail.com
Supporting Vendor
GOLD Star
North Florida
rdb
I also have recently purchased Steve's brackets and
will be doing an install this weekend.... PIX TO FOLLOW
VA
Now...
What do you do different if you want to relocate your e-brake to the rear wheels?
Chuck
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
use caddillac rear calipers with the parking brake built into them......
not sure if posers bracket is for caddillac calipers or not or
you could install a line lock and lock all four brakes
Fireman
Iowa Park. TX
Caddy calipers were $55 or so a piece. I'm a cheap bastard and will use a line lock if I just gotta have an e-brake.
Kansastitty
The ElDorado calipers will fit Poser's brackets, but running the cables to the p-brake and getting them adjusted is not easy. Why would you ditch the stock LC brake, are you doing some TC mods?
I would stick with the Monte calipers and K.I.S.S.
ed
Fireman
Iowa Park. TX
Got an auto tranny and np241 tcase so no stock ebrake! In a Pig so offset rear end and ctr output tcase doesn't hurt me.
Isotel
Crawlorado.com
It would be the GM Caliper, so i am Assuming the GM Dealer..
My Local Autoparts Place had the Bolts in stock.. Just bring in the caliper, and find the banjo bolt that fits
e rock
Monroe, WA
78toyFJ40 said:
David,
Was it a Nissan dealer that you got these bolts from?
I went to the GM dealership and the parts drone didn't want to just look for a couple. He looked them up in the computer... They were like $3 a piece, but they had none in stock and would have to order them from an east coast distribution center or something.
I went to NAPA with the parts in hand and found a couple in a bin of banjo bolts.
Sandy, UT
Thanks m8's!
I have a GM bolt but the hole in it does not line up with the hole in the Raybestos bajo fitting. I will try the good old NAPA.
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
as for the cadillac calipers with e-brake cable, my husband hates them on his GMC full size K5 truck, the e-brake cable ratchet mehanism is not terribly reliable, gets stuck, and is a pain to adjust.
As for the rear disk conversion: you will need a proportioning valve or a master cylinder that contains one.........
Poser
s-Moderator
Supporting Vendor
MN
78toyFJ40 said:
David,
Googled the part number and this came up... INFO
too funny.. :)
" Calip bolt from Cheby, 2 PN 88891786, $3.58 each "
TCSTARK
Master Debater & Cunning Linguist
Cumming, GA
Brackets, rotors and miscellaneous can be provided by Poser. Money well spent in my book.
