Okay I got a pair of calipers (with ebrake parts and cables) off of an '84 Eldo, and now I'm just doing up a list of what I'll need to do the conversion.
1) Rebuild kit for the calipers and caliper paint to clean them up, and pads (obviously)
2) Front rotors from a '90 Chevy K1500 pickup, centers machined to 4.185"
3) Soft line (preferably SS steel braided) to either connect to the hard line on the axle, or to run the full length of the axle from the T to the calipers. I think I'd rather just cut a few inches of hard line and use a short length of soft line in this case. These I'll get from TSM.
4) Brackets with hardware from TSM
5) New wheel studs (will I need longer studs or not? What diameter will I need for the Chevy rotors?)
6) Supplies to rig up the ebrake cable. Not sure how I'm going to go about this yet, but so far I'm planning to copy Calfj60's set up once I can see what it looks like.
Anything else I may need or should keep in mind while doing this? As always, I'm open to suggestions from anyone who's done it before and can help me out. I'm going to keep money aside for a proportioning valve, but I'm hoping I can adjust the factory LSPV to work correctly with a 4-wheel disc setup. If not, I'll eliminate that and install a Wilwood prop. valve.
