Rear disc brakes for FJ45
Discussion in '40- & 55-Series Tech' started by Radd Cruisers, Feb 22, 2004.
  1. Radd Cruisers
    Radd Cruisers
    7,954
    89
    Sep 28, 2002
    Vancouver Island BC Canada
    Canadian Tire made me change out the Mini truck rotors for the cruiser rotors on my FJ45 (federal inspection)? They felt they were unsafe for the truck due to its weight, come on they kick the crap out of the original drum brakes.
    Anyways, my new cruiser mech switched it over yesterday and it stops even better with the vented rotors.
    My big qestion is should I go with the older supra four piston calipers and do they share the same brake pads from the cruiser?
    Thanks
    Rob
  2. 73fj
    73fj Tho at sumbitch in ayer!
    1,148
    Media:
    36
    Albums:
    1
    194
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    what made you listen to someone at crappy tire?
  3. Landpimp
    Landpimp GOLD Star
    15,860
    Media:
    1
    1,902
    Mar 14, 2003
    Gig Harbor WA
    I don't think supra calipers work> supra master cylinder yes I think.
    I forget but I thought I used fj60 calipers and rotors on my swap.........but I forget alot ;)
  4. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,296
    Media:
    17
    Albums:
    1
    592
    Oct 1, 2003
    MN
    There was a thread on Pirate a while back that a guy was trying to use the rear Supra caliper, but IIRC, you are going to need the solid, non-vented rotor, like what was used on solid axle pickups and 4 runners...
    Good luck!
    -Steve
  5. Radd Cruisers
    Radd Cruisers
    7,954
    89
    Sep 28, 2002
    [quote author=Landpimp link=board=1;threadid=11892;start=msg108989#msg108989 date=1077556566]
    [/quote]
    I have to since they are the only Federal inspectin facility to deal with here.
  6. Radd Cruisers
    Radd Cruisers
    7,954
    89
    Sep 28, 2002
    [quote author=Radd Cruisers link=board=1;threadid=11892;start=msg109214#msg109214 date=1077581435]
    [/quote]
    That sounds doable, I have set of mini truck rotors off the front along with mini truck clipers. I do not need the ebrake as the FJ has a drive shaft park brake.
    I found a company that sells the mounts for FF axles to convert, then you can run one type of pads.
    Cool, thanks for all the help.
    Rob
  7. Landpimp
    Landpimp GOLD Star
    15,860
    Media:
    1
    1,902
    Mar 14, 2003
    Gig Harbor WA
    Edit........ I am a moron, you ment REAR disc....so never mind my drivel ;)
    [/quote]
  8. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    Rob,
    The Supra rears are all single piston, floating type until '93 when they get double piston, fixed calipers. The 4 piston caliper fronts don't appear in Supras until '93. None share the same pads as the cruiser.
    Here is a pic of a rear 79-81 Supra caliper on a SF axle converted to FF.
    Dave
