Rear disc brake conversion/parking brake
Poser
Oh...Durka Durka Durka.
Mod Emeritus
MN
If you have your parking brake on the rear axle after having done a rear disc brake swap, post up a picture or two of how you have the cables routed from the caliper to the frame, etc.
Picked up the generic cable kit that Downey sells, seems decent. Hopefully I will get to play with it some this weekend.
Thanks!
-Steve
hey steve, i dont have pics but could take some tomorrow. but may have to e-mail them, i never figured out how to resize them yet :doh: any way what i did was to use the cables from the caddy i got for free, just cut them to the leangth needed after routing around the frame, stripped the covering off to expose the steel cable and used cable clamps to clamp them to the factory 40 cable wich i also stripped to expose the cable. took some adjusting to get it right, it helps to have someone push in on the brackets on the calipers to let out some extra cable so you can tighten the clamps were you need them, works good been 2 years. hope this helps a little PM me if you need pics and i will e-mail them to you.
i was always curios about the downey kit, thought about trying it but it was 100.00 bucks i didnt have at the time. i would like to know what you think when done. please post up some pics when your done too. :cheers:
Poser,
I'm running the Cadillac El Dorado calipers in the rear, with the caddy stock cable system. The cables from the calipers are routed underneath my 55 in an "A" shape. The cable to the pull handle (floor mount) incorporates an adjustment block to set cable tension.
Will take some pics tomorrow of the pbrake system
Joe
Yes, pics please. I was just thinking about that conversion!. I want to put the parking brake on the drivers side kick panel. Foot actuated. I did not like the pull handle on my 55.
Poser,
Joe
Joe, I know this is very old, I want to run similar setup in my 40, Do you have any pics, or any other info that you could share?
