So the other day I had all fluids changed out. Rear diff had some small metal shavings on bottom drain plug. How worried should I be? How long till it completely craps out on me? What is the best way to repair or replace it?
Note: This feature currently requires accessing the site using the built-in Safari browser.
how hot should it get? and what's to hot?
It depends on load, ambient temp and oil type. I would think 180 would be pretty normal for dino oil on a 80degree day. I normally add 100 degrees to ambient temp for expected oil temp. A few degrees less if full synthetic. New or incorrectly setup gears will be well above 230. If you are using an IR thermometer, you'll need to account add about 50 degrees to the diff housing temp. This is farily inaccurate, but on an AWD vehicle with removable 3rd members you'll be able to understand the temp differential between front and read diff.
I wouldn't worry about switching to synthetic...advantages will include much longer service life, better protection in warm weather and a lower minimum temperature rating. Downside is cost. If you plan on keeping your cruiser around for a while, synthetic is a given...both diffs, xfer case, & engine...but my 100 has 88K on it and I wanted to change from conventional gear lube to synthetic. I called Amsoil rep. and was advised not to unless it was well-maintained. I purchased used at 84K, I don't know what the maintenance was. I was planning on changing over wife's Lexus RX 300 (103K) as well - those transaxles seem to get hot, therefore syn. would be better. I would not hesitate to put syn. motor oil in, is syn. gear oil's properties different?
Did the Amsoil rep say why he would not change to synthetic unless properly maintained? Seems weird.
0W-40 sounds WAY too light. Toyota calls for 5W-30, any good reason why you are not following their specs?
synthetic is a given...both diffs, xfer case, & engine![]()
