So, the rig has developed a slight rumble when i get off the gas pedal...
I checked for play on my rear diff (rig & T/C on neutral ),and i gots about a 1/8" play may be less (up and down). I'll also check for in/out play...... once the DS is off...
Rear diff was rebuilt (some 30k ago, with 7k of that mileage on less travel gravel roads) by reputable shop back home... it is a 4.11 and has a solid spacer in it...
I'm going to pull the rear DS and check the pinion nut and indent.....
My question is.... if loose, should i re-torque and replace with new pinion nut on it? (I think i have a spare pinion nut)
I'm 1600 miles from SurCal at the moment...
BTW i did find this thread, and might be alright, or not in too bad shape since i run a solid spacer and not a crush sleeve, bit thought i post, and ask here anyways...
Manu...
Manu...
