rear cargo "slider" windows - how to open easier - lube needed?
Discussion in '80-Series Tech' started by Cobra Jet, Jul 28, 2005.
  1. Cobra Jet
    Cobra Jet
    123
    Jul 11, 2005
    Southern NJ
    The rear cargo "manual" slider windows on my Cruiser appear to have never been used. So, during my cleaning session, I unlocked each of them. Once unlocked, I tried to slide them, but I'm assuming due to age and non-use, it is very difficult to slide either side open... Even once I was able to get the driver's side window slightly open, it was then hard to shut it as well.
    Do any of you have any tips/tricks for opening/closing stuck or binding windows?
    Is there a special lube to use so the windows will open/close easier? Is there a certain method of removing them completely to clean out the slider tracks?
    I just don't want to damage the rubber or seals by trying to force the windows open 100%, or while trying to close them again.
  2. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    I could see maybe alittle silicon spray around the tracks let it set for a min and give the windows a tug. I usally apply some silicon grease aka spark plug boot grease, to my window tracks every now and then to keep them from sticking.
    Also Armor All is silicon based so you could use that to try and unstick them and for future lube.
  3. Arsenal
    Arsenal
    140
    Feb 4, 2005
    i used compressed air to clean my tracks, then gave everything a liberal coating of silicone, works much better now.
  4. UltraFJ40
    UltraFJ40 ที่นี่และมี SILVER Star
    2,103
    21,953
    Sep 1, 2003
    Dito loob ng kubo kubo ko
    I'd try a "Q Tip" to clean inside the track with Hot Soapy Water. You may be able to get most of the crap out of there.
    Doug
  5. lahar50
    lahar50
    452
    Feb 27, 2005
    Indiana
    Silicon grease would be best.It might help soften up the seal.
  6. willywaxer
    willywaxer
    18
    Jun 20, 2005
    Silicone is good, I found a dry teflon lube I use for my bike chains worked great. Point is, you want something non-greasy so dust and dirt won't stick Keep the K-Y in the glovebox where it belongs :ban: .
