Rear bumper towing (1 Viewer)
Basalt, CO
Since the slee rear bumper is not towing rated, can you tow boat trailers and other trailers without any problems? :bounce2:
that would depend on how heavy they are...
IMHO, it is at least as strong as if not stronger than the OEM 2004+ LX "In-Bumper" hitch which is rated at 5k lbs. Could somebody with the "in-bumper" hitch could snap a pic of the rear undercarriage. I'd like to see how they have it set-up.
While I can't speak for the 100, on my 80 Kaymar rear bumper, it uses the same six bolt locations as the OEM trailer hitch had used. In addition it uses two bolts each side into the side of the frame rails and two more right into the pintle hook holes on the rear cross member.
Grand total - OEM six bolts rated at 5000lbs. Kaymar in bumper twelve bolts, but can't remember what it's rated. ROW on the 80 OEM under bumper hitch is 7500lbs.
Yo, Brent, you better not hang around these parts or before you know it, you'll need to buy a 100 :princess: ... :D
Never! :flipoff2:
