Took the beast in for a minor service at dealer this morning. Cheaper to have them change the oil rotate tires and inspect things than it is for me to do it by the time I dispose of the oil properly.
Rear pads down to 1mm. Need to replace. That, by itself isn't a problem and I've done it before. Quick call to Dan in a few minutes for the pads.
Service writer stated that tech said the rear rotors were showing some signs of a slight warping (and motioned - concave) and suggested having them machined. Forgot to ask what the specs (thickness) were on the rear rotors. They are still the originals w/156K on them. They quoted $465 for the 'rear brakes'.
I'd have to assume that is the pads and removal, machining and replacing the rear rotors.
I came straight to work so I've NOT done my reading in the FSM - yet. What's involved
wise to remove rear rotors? I know general consensus on this board is that it's not advisable to machine the front rotors. What about the rears? Should I just replace them with this kind of mileage and what's involved?
