I will be replacing my rear rotors in the next two weeks. I also will need to adjust the Ebrake as it's not so excellent. I'll be putting new shoes on it as well. I have two questions. The rear axle seal has recently been redone, so aside from that are there other things I need to address while down there?
Also attached are two pictures of what I believe are part of the brake system. There is some sort of balancing mechanism above the rear diff and then goes forward to connect to the device in the second picture. It appears to be leaking slightly, though my brake fluid level isnt to the minimum line on the resevoir.
