rear brake proportioning valve and return line
Discussion in '95-older Toyota Truck Tech' started by TRT2, Jan 23, 2004.
  1. TRT2
    TRT2
    1,771
    48
    Dec 23, 2002
    It appears my 85 4Runner has a return brake line from the rear proportioning valve leading to the front brakes.
    Whats up with that? what is the purpose? What happens if you abandon it?
    my 82 does not have one...
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,293
    Media:
    17
    Albums:
    1
    585
    Oct 1, 2003
    MN
    It is a load-sensing proportioning valve, meaning that if you are hauling more weight, the back end of the truck will set down lower, and allow more brake fluid to the rear to help stop, conversly, if you are empty, it limits the fluid flow to the rear in an attempt to not have the rear end lock up on you. I thought that the earlier pickups had a 'pre-set' proportioning valve right by the brake booster/master cylinder..
    Hope this helps.
    -Steve
