Rear bearing cap shim/gasket?
Hi,
I'm replacing the rear seal on my 11/ 72 FJ40 and in-between the block and the bearing cap is what I'm assuming is a shim (see pic). Can someone confirm? When I put this back together, should I use any sealant (e.g. ultra black) on either or both sides of the shims or just clean them up and reuse without any sealant. They didn't appear to have any sealant on them from the factory.
Also, based on my Haynes manual, the torque specification for the rear main bearing cap bolts is 85 f/lb. Let me know if anyone recommends otherwise.
Thanks,
Brian
Hi,
Thanks,
Brian
