Rear axle seals replacement with ARB??
Discussion in '60-Series Wagons' started by bigndn, Aug 15, 2006.
  1. bigndn
    bigndn
    4,147
    Media:
    35
    Albums:
    1
    45
    Jan 15, 2003
    Eagle, ID
    First off, I have searched until I'm blue in the face and can't find anything specific about replacing the rear axle seals and having an ARB air locker in my '84 FJ60.
    I think I've read just about everything I can find about replacing the seals, but what should I look out for (if anything) related to the ARB? Am I going to have to remove the 3rd to get the axles out? Anyone have any personal experience with this? :cheers:
  2. FJ60Cam
    FJ60Cam Supporting Vendor SILVER Star
    8,984
    10,916
    Nov 1, 2004
    Memphis, TN
    Here's the ARB installing instructions...
    http://www.ih8mud.com/tech/ARB-RD08.pdf
    Start at the end and work backwards, stopping short of pulling the entire third. After you pull the axles, the seal is right there smiling at you.
    Holler back if you get stuck.
  3. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,512
    4,474
    Mar 15, 2003
    Sacramento, CA
    I have done this a bunch of times. To remove the 3rd member, the axles must be pulled out of the side gears. That is the bottom line.
    Once the axles are out, replacing the seal is a trivial job.
    To put in an airlocker in your truck, the 3rd has to come out, so by definition, the axle shafts must come out first. Disassemble the first time and you will understand perfectly.
  4. 2mbb
    2mbb SILVER Star
    4,651
    125
    Sep 1, 2003
    WC, CA
    Are you asking if you have to remove the thrid member if you only want to replace the rear axle seals? The answer is no. You need to remove the rear diff cover and dissassemble the differential enough to get at the c-clips (remove the cross pin and the block, maybe some other stuff). Once you can remove the c-clips you can pull out the axles to get at the seals.
  5. bigndn
    bigndn
    4,147
    Media:
    35
    Albums:
    1
    45
    Jan 15, 2003
    Eagle, ID
    Sorry for the poorly phrased question. CD and 2mbb, thanks for the answers, I didn't know what I was going to run into having a ARB in the diff, but needing to replace the seals. Now I know what's going on.
    username? - thanks, I need to print that info off!
    THANKS, FELLAS! :cheers:
