I recently had to replace the driver rear axle seal after a short run at Bouquet Canyon/Rowher Flats OHV trail . Not necessarily a tough task replacing the seal. I did not prelube the seal lip prior to reinstalling the axle shaft. Within 3 weeks it is now leaking again. The only big change I have made is a set of tires (305-70x16 Hankook Dynapro AT/M). Balanced with dynabeads. There is no noticeable lateral or any balance issues. Is it possible that there is a tire issue causing this? Could it be my over-site in the lube issue? Or should I be looking at something like the wheel bearings (which are relatively newly replaced too)? Or something else that I am failing to see.
Suggestions please before I throw time and parts at it again.
Thanks!
Thanks!
