Checked my Passenger side rear brakes (Since the Driver's side had locked up on me figured I should do some preventative maintenance on the pax side). Covered in gunk and oil. Figure the axle seal must have been leaking so pulled the axle to replace the seal.
FWIW the metal seal that NAPA sells for $32 as a "direct replacement" is not, in fact, a direct replacement. Won't go in. Went to the Dealer and ordered two of the proper ones which will come Friday.
At any rate I'm cleaning stuff up and getting ready to sew it all back up when the seal arrives, but I'm confused about one piece that came out of the differential. It's the round piece with the holes in it. It's a cup shaped piece. I didn't see it fall out, just heard it (luckily).
The manual doesn't show this part nor the correct orientation. I was laying on my back getting this stuff out as I don't have a lift so couldn't see everything exactly.
What is the round piece with the holes, where does it go, and what is the orientation?
I attached pics of the manual as well.
Thanks
Thanks
