Rear Axel Seal
New Jersey
Rear axel seal appears to be leaking. I have a 76 40.
Do I have to take out the aussie locker to change the seal?
granite falls WA.
if its the seal inside the brake drum then yes you have to take it out because the c clips hold the axles in and they are now inside the aussie locker. and the axles have to come out to remove the seal and to put new in.
nuclearlemon
not an addict
Moderator
windy wyoming
take a screwdriver and dip it in grease...use it to pull the clip out from the locker so you can pull the axle...no need to pull the locker.
Folsom, CA
A expandable pencil magnet will work also, but, of course, it latches onto any metal which is just about everything in the third member. Heck it is all of it. ;p
