So my lockerless 80 is finally half lockered. I put an ARB in the rear finally got the project finished tonight.
Land Cruiser Northwest here in Portland installed the ARB into the diff for me. I wired and plumbed it and used the factory locker switch.
Slee's ARB air pump mount is a pain to install, but an absolute genious design! I have no idea how I would have mounted a pump in the engine compartment without it. The pain comes from the tight working quarters to get the mount installed, but it's a breeze once the mount is actually installed. The air pump just slides right in and it works great, even for the full size compressor that I have.
The air manifold block is another Slee part that relocates the ARB compressor relays to the firewall, where there's more room. The block uses two already predrilled holes in the firewall (at least I had the holes and used them). The block also allows the use of additional accessories, like a guage (I didn't use on) plumbing to an air tank (I didn't use that either) and an air hose fitting.
I did add an air hose fitting and have the ARB air hose from my truck. This will be my back up tire air source, with the powertank being the primary tire air source.
I used the factory locker switch but wired it up a little differently for this set up. The switch has two positions. Position one turns on the ARB compressor. Position two, fires the rear locker. While in position two, the ARB compressor still gets power, thanks to how the switch is designed, making it perfect for this type of set up.
If/when I add a front locker, I'll just add a seperate switch for the compressor and wire the dial switch conventionally for the front/rear lockers.
So far so good. No leaks, unlike the ARB in my truck. I had no idea you could fire and turn off the ARB multiple times without the compressor coming back on, when everything is sealed properly. I'd like to put one up front, but it's so much $$$$$. Someday.....
